Ir para o conteúdo principal
Reparos e mais informações sobre a geladeira Frigidaire FRT17L3FW—um modelo com freezer no topo sem gelo na porta, projetado com degelo automático e que inclui uma chave de resistência anticondensação. Esta página cobre informações para números de modelo que correspondam ao padrão FRT17L3FW*.
How do I remove the drip tray?
The drip tray fills with water, which cockroaches love. How do I empty and clean it?
Esta é uma boa pergunta?
Pontuação 5
10 comentários
i have a frigidare model FRT17L3FW1 how do i remove the grate/kickplate
por Compartilhar
I have this problem as well. Where the heck is the grate. Is it way back under the bottom drawer? Do we have to raise the refrigerator up to get to it? Please answer!!!
por Compartilhar
I have a bad oder in my fridge & freezer.I've cleaned it all out & put active charcoal in them both & it still has a bad oder.I checked the drip tray & found nothing buy it could use a good cleaning. Please help.
por Compartilhar
I have a bad order c oming from underneath my freezer and its leaking from back wht do i do
por Compartilhar
My freezer leaking from back it has a bad order coming from underneath it wht cou l d be wrong o r wht shall i do
por Compartilhar
Exibir mais 5 comentários
Adicionar um comentário
2 respostas
Solução escolhida
If you are talking about the evaporation tray on the bottom go the frig, it is not mean to be removed. Spray roach killer on the floor for any nasties that want a drink (make it bait for them).
A necessary byproduct of modern frost-free refrigerators and freezers is water condensation. Condensation forms inside the unit and is drained away from the freezer and refrigerator compartments down to a drain pan situated on the bottom of the appliance. This water evaporates, aided by the waste heat from the condenser, evaporator and fan motor. When a refrigerator's drain pan overflows, there are a number of potential causes that may be to blame.
Clogged Drain
A clogged drain inside the freezer or refrigerator compartment can lead to water overflow. Empty the contents of the refrigerator and freezer, and wipe out the drain using a solution of warm water and soap. The drains typically are located in the back corners of the food compartments, and can become clogged by food debris or ice.
Frozen or Clogged Drain Line
The drain line, leading from the drain inside the food compartment to the drain pan, can become clogged as well. Food debris can be forced down into the line and cause a blockage, or water draining away from the food compartment can freeze and stop up the line. In either case, a warm solution of water and vinegar can be used to free up the line. Use a turkey baster to pour the solution down the drain inside the food compartments, and ensure the drain is clean and clear. A pipe cleaner can be used to clean out the first few inches of the line as well.
Check the Drain Pan for Damage
A cracked or split drain pan can lead to water leaks and floor damage. Unplug your refrigerator before attempting to service the pan. A refrigerator's drain pan is located on the bottom of the unit, near the floor. It typically can be accessed by removing the grill on the front of the refrigerator and sliding the pan forward. Clean the pan thoroughly and check for cracks or splits. A damaged pan has to be replaced by a replacement part sold by an authorized dealer for your particular brand of refrigerator.
Condenser Fan Issues
Ensure your refrigerator is unplugged before attempting any maintenance with the fan. The condenser fan is located near the drain pan and keeps air circulating under the refrigerator, allowing the water that accumulates in the pan to evaporate before the pan overflows. If the pan is filled with water, and the fan is not running, it has likely burned out. A replacement fan can be purchased through an authorized service center for your brand, and typically can be installed by the user following the instructions
Esta resposta foi útil?
Pontuação 11
4 comentários:
Thanks for your prompt response. That's a bummer because it's already been made gross. I can sort of flex it to wipe it out so that's what I'll have to try.
por Compartilhar
If it has stuff growing in it, kill it with alcohol.
por Compartilhar
What a nasty system-can't remove the catfish blood reservoir, just flush with vinegar or whatever. Yuck.
por Compartilhar
The water is overflowing from the over flow inside the fridge, and runs from the overflow and goes into the veg box and is flooding.
por Compartilhar
Just watched a video about cleaning the drip pan on a Frigidaire refrigerator and it stated there are two screws that has to be removed to get the pan out. The refrigerator has to be titled backwards or laid on its back to get to the two screws. POOR DESIGN!!!!!!
Pontuação 3
4 comentários:
I concur! The cleaning of the drip pan is a normal part of regular maintenance if you regard a healthy environment in the kitchen. Whoa, a genuine design error!
por Compartilhar
Absolutely atrocious design. In addition to being hard to remove, it is not in the path of the fan and thus evaporation is less efficient than with other models.
por Compartilhar
WOW! Tipping over the fridge to clean a drain pan is assinine! You can't lay it on its back, no matter what way to lay it down you need to empty the whole F&F, and get a couple of good men to help hold it while another lays on the floor to unscrew the screw. What a genius that took to design!
por Compartilhar
We just had to do just that ! Something smelled funky underneath, and 3 yrs of stuff had accumulated in the bottom and around the bottom condenser . It took 2 hours . WHAT A HASSLE ! The designer needs to be fired ! I would design a fridge that can be opened to clean EVERYWHERE !
por Compartilhar
Adicionar a sua resposta
cee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 106
Ao todo: 143,356
