Ir para o conteúdo principal
Tela LCD widescreen de 4,3" com um processador de 333 MHz. Número do modelo PSP98510. O reparo deste dispositivo requer chaves de fenda comuns e ferramentas de alavanca.
Issue with power fuse
Hi there, bit of an odd one. Perhaps someone with a bit more electronics background could advise what the issue is here.
Issue: PSP doesn't power on. Charges fine.
On investigating the issue I checked the power fuse (Marked TB) with a multimeter to see if that was the issue. The fuse showed continuity so assumed it was fine.
Then by accident I checked the fuse again while a battery was connected and as I test the fuse with the multimeter the PSP powers on.
Is the fuse the issue? Seems when I bridge it that it powers on automatically, but why if the fuse is giving me audible continuity when I check it?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Also when I set the multimeter to ohms to check the fuse it shows as 0.00 as it should.
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Found the issue, the ribbon cable between the power switch and the mainboard was faulty. When I was bridging the fuse it was somehow triggering the power on sequence bypassing the switch.
Swapped the ribbon cable with one from another faulty console and worked perfectly.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Spot on. just finished fixing an old psp 200x with the action key ribbon and switch board from a decommissioned psp 300x.
por Compartilhar
ainda nao testei mais levei a um tecnico que me indicou esse problema (troca do flat) ainda esse mes vou comprar e trago nova resposta
Pontuação 0
Adicionar a sua resposta
Brendan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 56
Ao todo: 6,939
