Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Perguntas Visualizar todos
brown connector, holding the battery cable, came off from logic board
Hi
i had a very great problem with my iPod video 30 GB, and i hope that someone can help me.
I tried to open it, but I wasn't careful of use a small opening tool to slide up the brown connector holding the orange battery ribbon cable in place;
so brown and gray connector came off with battery ribbon and was unplugged from logic board
my only question is:
can i repair it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Well, if you are really confident in your soldering abilities, you could attempt to re-solder the connector back onto the logic board. Otherwise, I think a new logic board is in order. It's a very frustrating situation you are in, one I have been in myself before. Here is the guide, and here is the part.
Imagem de iPod Video (30 GB) Logic Board
Produto
$29.99
Esta resposta foi útil?
Pontuação 6
4 comentários:
thanks...
but what did you do???
por
Well, i mistakenly used the incorrect tool to lift the brown tab up, and broke off the entire connector. I haven't yet replaced the logic board, but that will be the necessary next step.
por
ok ..good look
por
you can buy the part you need at the following link
http://www.parts4ipods.com/IPOD-5/55GEN-...
Pontuação 1
1 comentário:
+great find, even so it's an old question...super research
por
Adicionar a sua resposta
john será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,985
