Ir para o conteúdo principal
O Visual Land Prestige 10 é um tablet com acesso à internet fabricado pela Visual Land INC. Esta página do dispositivo e os guias de reparo subsequentes mostrarão como remover e substituir os componentes do aparelho.
cant charge my table
I cant charge my table, do your company sell one that will fit my device
Esta é uma boa pergunta?
Pontuação 9
10 comentários
Mine will not charge, it's only 2 months old
por
Also when I try to turn it on a battery symbol with a triangle in it appears
por
I have the exact problem, is there a solution? Besides buying a new one.
por
I am also having this problem, getting very frustrating!
por
Mine and my daughters will not turn on either and both are only 3 months old!
por
Exibir mais 5 comentários
Adicionar um comentário
6 respostas
Pergunta mais útil
the recver end of the charger is pushed back in not allowing the power cable to make contack . it needs to be pused back in place to make contack agend.
Esta resposta foi útil?
Pontuação 5
4 comentários:
How do you pull the receiver end back out
por
How do you pull the charger piece back because mine is pushed back
por
How do I pull back out or where can I send for repair
por
do you have to open in up
por
My tablet will not charge. The end of the charger will not connect to tablet?
Pontuação 1
1 comentário:
I am having the same problem! What is the answer?
por
well do you have one
Pontuação 0
I would like to have this uniy replaced there is something wrong this is pnly about the twenty time this has happened i am tired of this.
Pontuação 0
It is not turn on at all and not change
Pontuação 0
tablet dose not response or turn on or off
Pontuação 0
1 comentário:
My charger wobbles when it is connected to the tablet and the charger end does not go in completely. It won't charge. What gives?
por
Adicionar a sua resposta
kathleen pruitt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 36
Ao todo: 1,749
