Ir para o conteúdo principal
Announced on September 9, 2015, the iPad Mini 4 maintains the power of an iPad Air 2 in a smaller form factor.
20 Perguntas Visualizar todos
iPad Mini Touch Screen Compatability
Are the digitizer touch screens for the Mini 3 & 4 the same touch screen as on the earlier 1 & 2 models other than the finger print sensors? (which is transferred over) IC connector and all? Or are they different completely. Mainly what I'm getting at is I have a few iPad Mini 2 digitizers here, can they be used to repair the Mini 3 or 4? Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
I dont believe they are. I believe the mini 3 is a different digitzer than the two and on the 4 it might be different as well, but i could not find a part for it! Keep in mind on some of their new ipads like the Ipad air 2 and pro they are fusing the displays to the digitizer so it may be that way on the mini 4, hope this helps!
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks for the quick reply. Not seeing any Mini 4 digitizers out yet, why I asked. Aware of the Air 2 and Pro using "fused" screen.
por
I know for sure that the iPad mini screens for the 1&2 will not work for the iPad mini 3 because the home button on the 3 is not the same size as the 1&2. The iPad mini 4, I've not seen one of those but thinking the LCD and glass are going to be fused.
Update (01/04/2016)
I think the iPad mini's have little traps in them from Apple to prevent us from repairing them. I think the best guide for repairing the iPad mini is on a website called iPad rehab, google it , and using high quality screens with the copper edges and kapton tape and you will not have any issues.
Pontuação 0
1 comentário:
Had a feeling they were not the same. Stopped repairing the Mini here a while ago mainly due to the lcd removal risk. Had 2 or 3 back then in one week, where I screwed up the lcd's on them, so I stopped repairing those. Thought I'd get back into doing the Mini again. Thanks!
por
no, ipad mini 1/2 is same digitizer but ipad mini 3 and mini 4 is different, ipad mini 3 you can change a digitizer by yourself easily, ipad mini 4 you can't, you normally need a lcd digitizer assembly for ipad mini 4, only if you are a refurbished factory have special cut glass tools then you can change ipad mini 4 digitizer.
Pontuação 0
Yes you can use iPad Mini 1/2 digitizer in iPad Mini 3 but you can’t use the touchID. The iPad Mini1/2 uses the same type and size of plug as the iPad Mini 3. I have tested it and works fine.
Pontuação 0
Adicionar a sua resposta
lightspeedssupply será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 17
Ao todo: 2,738
