My camera won't shoot.
The door that covers the battery fell off. Would that keep the camera from working?
Esta é uma boa pergunta?
The battery door on most Canon DSLRs actuates a tiny little switch that shuts the camera down as soon as you open the door. Therefore, if the door is missing, the camera can't turn on.
The switch plunger is visible on this pic, just to the right of the red circle mark:
https://d3nevzfk7ii3be.cloudfront.net/ig...
You can do the following:
Esta resposta foi útil?
Hi,
On mostly all cameras the battery compartment door maintains a constant pressure on the battery to ensure that it keeps in good electrical contact with the terminals in the camera. Without that pressure the camera would probably not start due to effectively a 'no power' situation or if it did start it might be intermittent in its operation.
On some cameras besides the above reason there are also connecting strips inside the cover which ensure that the batteries are connected in the correct manner (if inserted correctly) to provide the correct voltage to make the camera work. e.g. cameras that use 2 x 1.5V AA cells need to be joined in series connection to provide 3V. This is done by the cover.
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 48
Ao todo: 2,096
