Ir para o conteúdo principal
Um laptop de 15,5 polegadas conversível com tela tátil da Sony.
Flip 15 will not boot - Error code: 0xc000000f
I downgraded from Windows 10 to 8.1 the other day and after rebooting I got the error message below.
'Recovery
Your PC needs to be repaired
The boot configuration date for your PC is missing or contains errors
File \EFI\Microsoft\Boot\BCD
I have tried 8.1 installation media via USB as my Vaio doesn't have an optical drive and each time I got in to it I get that blue screen and when I press refresh or re-install it says "The drive where Windows is installed is locked.Unlock the drive and try again."
What can I do to resolve this? I have tried check disk, tried bootrec but nothing works, any help would be gratefully appreciated.
(If the hard drive needs replacing, what would I need and where do I get it from?)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Check here this might help: http://www.tomsguide.com/forum/id-185218...
Esta resposta foi útil?
Pontuação 1
Pointers to be focus when you encounter this error.
Corrupt boot sector due to power outages, virus/malware infection.Damaged hard disk due to power outages.
Corrupt system files due to improper shutdown and/or power outage.
Damaged Hardware
Check this website for Solutions
https://www.errorsolutions.tech/error/er...
Pontuação 1
Adicionar a sua resposta
Kian O'Donoghue será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,186
