Ir para o conteúdo principal
The Motorola Moto G (2nd Generation), also known as the Moto G2, is the 2014 successor to the Moto G. The Moto G2 is equipped with a 5-inch 720p display and a Qualcomm Snapdragon 400 processor. Model numbers XT1045, XT1040, XT1039, XT1069, XT1068, and XT1064.
78 Perguntas Visualizar todos
Upper speaker not working after disassembling
I had to replace the screen on my Moto G 2nd and thus, I disassembled the phone. After putting everything together, the upper speaker does not work any more. I tried a lot of times to readjust the speaker but in most of the cases it did not work at all. Sometimes, I heard something, but the sound had very poor quality with lots of cracking in it. Furthermore, in many attempts I saw that the speaker was attached to the vibration motor magnetically when I opened the case.
With a new screen came a new case, so it is not the original one. Could there be something different? Should I try to glue the speaker on its place such that it is not attached to the vibration motor? Maybe the speaker is too low in the case? It is connected to the mainboard via the rear side. Did anyone have similar problems?
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It turned out that one speaker is simply broken. I switched both speakers and realized that only one is working.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I didnt understand your answer. After all only one of your speakers are working? That means the circuit of one speaker dont work anymore?
por
Adicionar a sua resposta
Dan Eff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 319
