Ir para o conteúdo principal
iMac display not working
I have an iMac 2010, 21,5" which has hardrive problem and replaced it. While connecting its LCD with display connector cable, the cable got damaged at one end. I got new display-port connector cable, but still display is not working.
When I connected with external monitor, its working fine.
I asked at a local repair store they told me that it was either the LCD panel, or the SATA/Board (Logic board?) which would even be more expensive.
I thought its a LCD problem, got LCD from ebay but still the display is not working.
I did a SMC/PVRAM Reset, but this did not solve the problem.
I used flashlight and cant see anything on the internal screen.
My question is whether it's possible to determine if it is the logic board, cable connection, the Backlight controller or the LCD-Panel.
Thanks for your answers,
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Fans running at full speed too?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
You should try the diag leds first to see if its the lcd. They are just above the mic connector on the logic board. The #4 led is green if the lcd is making connection with the motherboard. If the #4 led is green, maybe the motherboard defective because you changed the lcd and the lcd cable allready.
Esta resposta foi útil?
Pontuação 1
2 comentários:
I did check the LED, #1 LED green, #2 LED green, #3 LED green but #4 LED is off.
por
If you allready changed the lcd and the lcd cable i am thinking about the motherboard connector. Try to change the lcd temp cable the thin one.
por
I had the same problem. Only external video, LED4 of. In my case, inductor L9000 of the logic board was gone. If you want, have a look at my post
After HD changed, fuse (wall) tripped, no internal video, but external
Regards.
Pontuação 0
2 comentários:
SAme problem here.. already bought the fuse.. but can't locate the L9000 circuit on my MB..please Help!
por
Hi Christiano,
I just updated my answer to my own post. Hope, this helps.
Regards from Hamburg
por
Adicionar a sua resposta
Shailender Rachamalla será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 928
