Ir para o conteúdo principal
O Visual Land Prestige Elite 7Q é um tablet de 7" com processador quad-core, 8 GB de memória e vem com Android 4.4 (KitKat).
The sound doesn't work,
After I used Skype and made a call, ever since then my sound doesn't work , but I can use headphones and they work. I have a visual land
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi,
Have you turned off the tab and turned it on again?
por
Adicionar um comentário
1 resposta
There are many answers to this question, as I will list below.
  1. The speaker could be faulty
  2. A(some) wires can be loose or cut in between the speaker and the CPU
  3. Some apps will only support headphones
  4. High volumes on a some speakers may damage the speaker temporary or permantly
Here are some ways the the problem can be fixed, or resolved.
  1. Doing a soft reset
  2. Doing a hard reset
  3. If the tablet froze unplug it untill it dies, then turn it back on (this my take form a minute to a week, matering on you screen brightness or/and how much battery is left)
  4. Push the reset button
If all fails,
  1. Bring it to a servive guy and see how much the repairs will cost( if the repairs are more expensive then the tablet itself, get a new one)
  2. Find a speaker that you can mount on the back of the tablet that connects using a 3.5mm headphone port or a speaker with an adapter for a 3.5mm headphone jack
  3. (only recommended if you give up) Find an awesome way to destroy it (for ex. mounting it with ropes on 2 of your cars and ripping it to pieces or do some target practice and shoot it with something like a 22)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jeanise será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 529
