Ir para o conteúdo principal
The Asus X401A-BHPDN37 was released in September of 2012. It has a slim 14” high-definition display with a 320GB hard-drive, which offers spacious storage and fast read/write times.
5 Perguntas Visualizar todos
Pergunta encerrada
part # that keeps Ethernet cable end secure in the jack
In Ethernet port the bottom of port had a little secure flap or something that secures the Ethernet cable end once plugged in so cable won't move and is locked in, it broke off, need to replace it, what is the part # for item please?
I have the Asus X401A-BHPDN39 laptop
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
narut, that part should be part of the ethernet jack. In order to replace it you will have to replace the complete jack which is soldered onto the motherboard. To get the right jack you will have to give us the numbers that are on your motherboard.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 206
