Broken cable connector replacement
Hi, I recently damaged a couple of the female cable connections on the logic board of my Macbook Pro (while attempting to change thermal paste) and was wondering if anyone knows if and where I can get replacements. The plastic clip that the cable pushes into has broken. Am I stuffed or is there a work around or replacement part for this? Long shot but I thought I'd give it a try...
Esta é uma boa pergunta?
Pontuação
0
swilton give us the 820-XXXX number of your logic board so we can look it up. Also, it will help if you post a couple of images of the damages with your question. That way we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente to add images.
por oldturkey03
Doesn't look that hard to fix. Find someone local that is good with soldering.
Just soldering it directly without using a connector seems the quickest fix.
por Alexander Hollander
