Ir para o conteúdo principal
Cant open any applications even after hard rest
Phone was working pretty well since the last three years. Last night suddenly, all of my applications stopped working. Even after hard reset and again downloading all of the same applications they won't work. What could be the matter ??
Esta é uma boa pergunta?
Pontuação 8
13 comentários
Hi,
Did you update any apps or the phone just before it stopped? If so can you remember which app? If so uninstall it and see how it now goes. If you didn't do anything like that, when you hard reset, did the preloaded apps (the ones that came with the phone) work? The phone must be working of a fashion, you said that you downloaded all of the same apps again. Maybe one app has again altered something on installation and that has affected the rest. Just an idea. Maybe you could try to hard reset again. Check that the phone works and that the apps already installed work. Then start downloading your apps one at a time and trying them. When you are satisfied do the next one etc. Long process but maybe the only way to find out.
por
1.I didn't update any app or my phone.
2.The preloaded aren't working either. I did a hard reset and downloaded a completely new app. But that new app is also not working.
3.I uninstalled all the same apps again and did a hard reset again. And downloaded a new app. But... same problem.
4. WhatsApp, OneDrive, Music Player,Video,etc. aren't working (after two hard resets)
por
Hi,
Is this link of any help to you?
http://www.microsoft.com/en-au/mobile/su...
por
I'll try that way and revert back soon :)
por
thank you so much :d :d :d it worked !!!
por
Exibir mais 8 comentários
Adicionar um comentário
3 respostas
Pergunta mais útil
Are the Phone in SAFE MODE ??? App are installed in SD memory Card or In Phone Storage ?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yes my phone in safe mode And app is install in phone storage my name is Rajat
por
Sounds like a software issue.
Try doing a hard reset using the following software
https://support.microsoft.com/en-gb/help...
Pontuação 0
I will try plugging in the wall and doing the hard drive hard reset
Pontuação 0
Adicionar a sua resposta
rohiet bhoslay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 13,259
