Ir para o conteúdo principal
The Galaxy Tab Pro 8.4, produced by Samsung, is an Android based tablet which was released on January 2014.
21 Perguntas Visualizar todos
Pergunta encerrada
Charging port seem to be broken
The flat pin within the USB port is bent downwards and doesn't accept the cable connector. I guess I have to replace it. Does anybody know where to find a repair manual or disasembly instructions? I have searched YouTube and googled for help. So far without luck
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Estou com o mesmo problema.
por
I am vaiting for a replacement port from Hong Kong. I have opened the case which was pretty easy following the procedure in the video suggested to me. There seem to be easy access to the port as you don't have to move off a lot of stuff, making it easy to be removed and replaced
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Here is a link which shows how to access the battery in a Samsung Galaxy tab pro 8.4. From what I can see in the video you should be able to access the USB port to replace it. At 2:52 minutes into the video you can just see the connector of the USB port flex cable plugged into the board just below the green connector with the blue and red wires (under the man's fingers).
https://www.youtube.com/watch?v=lEVFYQks...
Also here is a link for the USB port. It is not a recommendation to purchase from them, it is mainly to show what it looks like.
http://www.etradesupply.com/samsung-gala...
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Really helpful. Thanks a lot
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 903
