My Magellan GPS 9250T-LMB wont come on
I was on the road, my GPS was working. I unplugged the power cord from the car outlet. 5 minutes later, I plugged it back in, but my GPS won't come on. To check if the cord got bad, I checked another cord, but the GPS won't come on. I opened the GPS and checked the voltage of the battery. It shows 3.7 volts. Please tell me your opinion on the problem. Thank you.
Esta é uma boa pergunta?
Hi,
Have you tried resetting your GPS?
To Reset: Slide the power switch all the way over to the left and hold for 5 seconds. Release then try to turn on your GPS
por jayeff
es i tried slide power switch to the left like you set, but it still it not come on
por roleg1313
I have the same problem and the reset did not work!
The light that shows it is plugged in to power is the only thing that works at all. How can I make it come on again?
por Craig Sedgwick
