charging port does not work
The pin inside the charging port seem to be broken.
Esta é uma boa pergunta?
i think you just answer your own question.
Esta resposta foi útil?
Well, not really. I was hoping for some advice on how to get access to the plug. I didn't find any repair videos on YouTube and no repair manuals
Ok, that's a better question. If your problem is the port as you say, you have to swap charging flex cable which is pretty simple compared to Samsung normal approach of soldering port to the motherboard.
Here is a link how to open the tablet
https://www.youtube.com/watch?v=lEVFYQks... (0:25 - 2:20 time)
And here is link to buy DOCK CHARGING FLEX CABLE http://www.parts4repair.com/dock-chargin...
When removing old port from the device be carefull not to damage pinheads in the process. Hope this was more helpfull and gives you enough information to proceed with the repair. Good luck.
Thanks a lot. I am afraid my first question went into cyberspace in an amputated version.
does the port pull out or do you have to remove the plastic on top of it
Is there instructions on how to remove the charging port or flex cable?
yes is understad
was good and wounderfull
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 1,212
