broken inside screen need help
The inside of my screen has cracked and now all I see is crazy colors how do I fix it
Esta é uma boa pergunta?
Sounds like you need a digitizer and an LCD .You should go to wherever you bought the phone to see if you can get parts through them as this is not a common phone and aftermarket parts are not readily available.
Esta resposta foi útil?
I think you are out of luck, I had a look around and couldn't find any parts for this phone, you will need to replace the lcd/digitiser to get this phone to work again if you can find it. Good luck.
You can usually find them on amazon or ebay but try google to find the parts
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 53
