Ir para o conteúdo principal
Trem elétrico Thomas e seus Amigos operado por bateria com trilhos.
Where to charge the train
Where do I charge the train, If I go under the seat which plug do I plug the charger to, so the train can work I have no idea what I am doing.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Apparently it's at the back of the train. The charger, hopefully you have it, is an unusual shape, and there shouldn't be any mistaking where it goes. Sorry I couldn't be more help
Esta resposta foi útil?
Pontuação 2
1 comentário:
thanks a lot for your answer
por
You must remove the two Phillips screws on the black plastic seat. Remove the seat. Unplug the 2 prong hard plastic connector that goes to the 6volt battery. Connect the charger directly to the 2 prong connector that goes to the battery. Wait 6 hrs and then unplug the charger. Reconnect the connector that goes to the motor back to the battery. Replace the seat and tighten the 2 screws down. Enjoy!
Pontuação 0
Adicionar a sua resposta
Constance Briscoe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 79
Ao todo: 7,080
