Ir para o conteúdo principal
Why PowerBook does not start with power cable connceted
Hello,
Few months back my powerbook stopped charging. I replaced the charging cable and it worked for few days. soon, it stopped charging did not boot. I took it to Mac store, they put in a charged battery and connected the power, even then the powerbook would not start. the guy there said it needs the power supply replaced. Can you help?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
You said he replaced the battery and power supply and it still would not start, and then suggested a power supply? Well obviously that won't work. First reset the SMC by removing the battery and AC adapter and holding down the start button for 10 seconds. I would remove the battery and connect the AC adapter and see if you get anything. Any lights? Any sounds?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Good answer +
por
Adicionar a sua resposta
ssrmsr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,102
