Ir para o conteúdo principal
Repair guides and support for motherboards and CPUs.
165 Perguntas Visualizar todos
Pergunta encerrada
Weird temperatures with CPU
Hello !
I don't know if this is an issue or not but i have a Haswell i5 4460 and on idle i get 30C , with youtube and a few apps opened i have 40-45c and on max load ( I tried Borderlands And Fallout 4 on ultra ) i never got more than 40C , I use HwMonitor , sould i use another heat measuring program or is my CPU made out of magic and doesn't overheat?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hikary Katsu, those temps look normal , there should be no issues in those ranges.
Haswell i5
Idle Temp 28 to 35°C
Normal Temp 47 to 60°C
Max Temp 72°C
Esta resposta foi útil?
Pontuação 3
1 comentário:
I was about to say the same as oldturkey03. The temps sound pretty normal to me. The load temp if accurate is great and you should have a good long lasting cpu if this is the case. You could also try some other hardware monitoring software such as speedfan to see if it reads the same as HWmonitor.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 81
