Surface Pro 2 shutdown randomly
My surface Pro 2 shutdowns randomly without reasons, I've found a pattern: every 30 minutes with 0 seconds! exactly 30 minutes. Tried resetting, installing recovery image. I've had an issue installing recovery image: when I choose "fully clean the drive" after 30 minutes 0 seconds (33% installing) surface shutdowns by itself. I can only install the recovery image choosing the "just remove my files" option because takes less than 30 minutes. It's not a driver issue, not an OS issue, not heat issue, as crazy as it sound, it's a time issue (¿planned obsolescence?)
I CAN'T FULLY CLEAN THE DRIVE the Surface turns off by itself before finnish. I've contacted 4 times to Microsoft support and last time they were unable to get me another solution.
Esta é uma boa pergunta?
you should try bios reset first and and seee
por Abdul Galib Compartilhar
I've tried to reset from bios menu but there's no way to do it
por brunonemer Compartilhar
