Ir para o conteúdo principal
O Dell Streak foi lançado em 13 de agosto de 2010 e está disponível exclusivamente na rede celular da AT&T nos EUA.
Can I replace the Speaker
The speaker on this device is totally rubbish. It cracks and crackles, the speakerphone is almost unusable. Is the part easily replaceable and if so can you recommend a compatible excellent replacement?
The ear speaker is also horrible in that you cannot hear anything unless you've absolutely directly paired your ear canal and the tiny slit. Any suggestions of a solution for a louder speaker here?
Thanks, Ravi Shanghavi, Ottawa
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Imagem
Imagem
I have had people tell me that "removing the cover over speaker helps with sound volume" so I gave it a try and will describe how to here. I will assume that you saw the teardown post for that is the best how to guide I've seen to date. For this mod you only need to remove the plastic bezel that covers the internal speaker.
Once cover is removed (it is held on with rather sticky tape so be careful not to crack it. I reccomend using the plastic tools shown in teardown post) locate the sticker covering the speaker
Imagem
using tweezers, or whatever floats your boat, to peel off sticker.
Imagem
Now simply replace the plastic bezel. I noticed a slight difference is sound, especially with directionality. I no longer have to have slit directly over my ear canal. Slightly off center works well now.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ravi Shanghavi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Ao todo: 2,370
