Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
How can I fix a battery locking screw that snapped off?
I was installing a new replacement battery and it was a snug fit; I guess I turned the coin a little too strongly, and the plastic piece that covers the turn lock snapped off. What's the best way to go about getting this fixed? Could anything worse happen if I don't fix it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
This problem requires replacing the bottom case--not a task for the faint hearted. If you can retain the battery as is I think I would leave it alone. Ralph
MacBook Core 2 Duo Lower Case Replacement
MacBook Lower Case
Esta resposta foi útil?
Pontuação 3
2 comentários:
+ agreed
por
RGCh say: Mend button in position with two drops of a flexible mending compound, let it dry 24-48 hours and it's fixed.
Pontuação 0
1 comentário:
Would you provide a link to RGCh?
por
Adicionar a sua resposta
fredvr22 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,055
