Ir para o conteúdo principal
The Samsung NX1000 is a digital smart camera that was released April 2012
Where can I obtain the cd rom
Where can I obtain the cd rom that came with the camera or is a digital file available online to reset the camera back to factory setings
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
You can reset your camera's setup and shooting options to factory default, (Date, Time, Language and Video Output settings do not change).
Go to Menu > Settings 1 (gear wheel with 1 in box) > reset > Yes or No.
Performing a firmware update will perform the same function as the above reset procedure.
Here is a link to the user guide describing the reset function. It starts on p129 and carries over to p130.
http://www.manualslib.com/manual/416447/...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
kisha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 321
