Why does not the display screen work?
Sometimes the LCD display will go black for seconds before turning back on to normal.
Esta é uma boa pergunta?
There could be an issue regarding the power connection. Make sure the battery is good first and then check all the wire connections. If that isn't the case, follow the disassembly guidance and take it apart and check if the LCD needs to be replaced.
Esta resposta foi útil?
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 666
