Ir para o conteúdo principal
Water Dispenser dispenses water slowly
I have a GE PFSS2MJXASS Refrigerator and the water dispenses slowly. Ice maker works fine. I recently replaced the water filter and valve and that did not fix the problem. When i unscrew the water filter and replace it the water dispenses fine for a short time and then the flow slows down. I hear air when the filter is connected to the refrigerator so i suspect the problem is with the part that you screw the water filter into. Any ideas on how best to fix would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You need to flush the air out of the water lines after installing new filter. Place a tall/large cup under the water dispenser and run the water untill the air is released. It usually takes 5 minuets or more and at least a gallon of water to remove all the air.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
markrubin25 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 54
