Ir para o conteúdo principal
Huawei Ascend G510 Android smartphone. Announced 2013.
huawei ascend 510 dead wifi
sir my wifi is open but searching only not accept any wifi so plz help me
Esta é uma boa pergunta?
Pontuação 3
2 comentários
ewhing was stoped howe i can repaer som one tol only to change plak aqllryt
por
This should another question, not an answer to one, also what is an ewhing, plak and aqllryt
por
Adicionar um comentário
2 respostas
Solução escolhida
irfan sanam,
Hope below steps will help you to fix the fault
Step 01
Open System Settings --> Wireless & Networks -- >> WiFi connection, touch on the Wi-Fi network that you’re unable to connect and select option “Forget.” after that try to reconnect
Step 02
Open System Settings --> Wireless & Networks --> WiFi Connection, press Menu button and select Advanced----> select WiFi Frequency
Check with Auto mode and try to connect with 2.4Ghz band.
Step 03
Backup all data and Reset the phone. after resetting phone try to connect with WiFi
Esta resposta foi útil?
Pontuação 2
2 comentários:
after my phone get wet it didn't able to connect in wifi.. What should i do?
por
Check the WiFi chip, clean the chip using IPA and re-hot the chip. see whether chip bins to work. if not, check the 3.3 power rail present- if yes replace the WiFi module
por
Mary set ka wifi on h ne hota
Pontuação 0
Adicionar a sua resposta
irfan sanam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 5,333
