Ir para o conteúdo principal
Guias de reparo para uma grande seleção de câmeras digitais Panasonic.
Error message "System error (Focus)"
Panasonic Camera TZ20
When I start my camera the lens extract to a maximum, tries to focus, then the lens closes and an error message appears on the screen "System Error (Focus)".
After hours of searching the internet and trying different solutions, i have still the same problem. I even bought a new lens for my TZ20 and have still the same error message.
Can anybody help me on that issue?
Thanks a lot...
Esta é uma boa pergunta?
Pontuação 4
2 comentários
Hi Fabiem, Were you able to get the TZ20 focus error problem fixed as I have the same error and am searching for some help.
regards, Tony
por Compartilhar
Legendaire! Dropping and thwacking it worked for me too! Hooray!
por Compartilhar
Adicionar um comentário
2 respostas
Solução escolhida
Bonjour,
J’avais le même problème avec un TZ80, et j’ai trouvé la réponse ici : https://www.commentcamarche.net/forum/af...
La solution est invraisemblable, mais d’un efficacité incroyable. J’avais du mal à y croire, mais c’était l’essayer ou bien envoyer mon appareil en réparation. IL SUFFIT DE LAISSER TOMBER LA CAMERA DE QUELQUES CENTIMETRES, et le choc règle le problème. En l’occurrence, je l’ai laissé tomber de 5-10 cm de haut sur une table avec un peu de papier en-dessous pour amortir le contact, en position droite, comme pour prendre une photo.
Bonne chance! Et que pour une fois les anglophones apprennent le français, cela en vaut la peine !!!!
Esta resposta foi útil?
Pontuação 8
26 comentários:
Translation:
Hello
I had the same problem with a TZ80, and I found the answer here:
++https://www.commentcamarche.net/forum/af...
The solution is unbelievable, but incredibly effective. I was struggling to believe it, but it was trying it out or sending my camera in for repair. Just drop the CAMERA from some centimeters, and the shock settles the problem. In this case, I dropped it from 5-10 cm high on a table with a little paper underneath to cushion the contact, in the right position, as if to take a picture.
Good luck! And that for once Anglophones learn French, it is worthwhile!!!!
I’m afraid to do this with my LX100 though.
por Compartilhar
I tried this too - and it worked - amazing!
por Compartilhar
Worked for me too, thanks !
Carsten
por Compartilhar
Was about to throw my camera away (too expensive to repair) so in desperation I tried this. It worked!!!
por Compartilhar
Had the same problem, replacing the battery and SD card didn't help - but this solved the problem!!
por Compartilhar
Exibir mais 21 comentários
Methods to fix-
Method 1. Run System Restore
Method 2. Run Check Disk.
Method 3. Run System File Checker & DISM.
Method 4. Run Malware/Virus Scan Of Your Entire PC System
Method 5. Set Windows 10 Theme to Default
Method 6. Change Sound Scheme of Your PC System
Method 7. Reset Windows Store Cache
This may help you,
Rachel Gomez
Pontuação 0
1 comentário:
Dear Rachel - this is not the reply to the question posed - which was how to get a stuck lumix camera back working again !!!
por Compartilhar
Adicionar a sua resposta
Fabien Rousseaux será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 28
Últimos 30 dias: 92
Ao todo: 10,492
