Ir para o conteúdo principal
Informações de reparo e guias para o Apple iPhone 5s, anunciado em 10 de setembro de 2013. Modelos: A1533, A1453, A1457, A1528, A1530, A1518
My iPhone is disabled
I switched off my iPhone and when I turned It back on it said iPhone disabled connect to iTunes , what should I do ?,???
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
it still not working
por Compartilhar
i powered my phone back on and it is just displaying the itunes and charger icons
por Compartilhar
Adicionar um comentário
4 respostas
Reset, hold both home button and power button at the same time for about 10 seconds until the iPhone begins to restart. If still problem after this reset you will need to Restore the iPhone with iTunes on computer.
Esta resposta foi útil?
Pontuação 0
If you cant get your iphone's password back and if you dont mind factory resetting it and getting rid of all your stored data than go to another device that has find my iphone, you want to got to your iphone and press "Reset iphone" after that your iphone will be factory restored and you will hve to save your last backup and just install all of the things you had previously on it
Pontuação 0
this is how to fix the problem without iTunes.
Disabled iPhone: How To Fix Without iTunes
Pontuação 0
yes my itune is disable
Pontuação 0
Adicionar a sua resposta
zoey blues será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Ao todo: 589
