How do you know when to change ink
how do you know when it needs ink
Esta é uma boa pergunta?
Hi,
There are two ways to check the ink levels of the cartridges in your printer.
1. There is an Ink Level Gauge in the Control Panel on the printer.
It show the ink level information for each print cartridge, four indicators for the tricolor
cartridge and four indicators for the black cartridge. It also displays a warning for print
cartridge problems.
2. To check the ink levels from the HP Photosmart Software on your PC
In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button the Printer Toolbox appears.
Click the Estimated Ink Level tab.
The estimated ink levels for the ink cartridges appear.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 621
