Ir para o conteúdo principal
A cordless home phone handset manufactured by Uniden America Corporation in 2001.
3 Perguntas Visualizar todos
Unregister without base issue
I acquired a used phone which when I went to unregister it from its original base, I missed a step in the procedure to identify I did not have the base and I am now in a state where it says I need to put it on the main base to unregister it. I do not have a main base with that capability. Is there a way to reset the handset memory such that I can perform the unregister function again correctly. Nothing I have tried works.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
This link may be of interest to you
http://www.manualslib.com/manual/184779/...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
E Pippert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 135
