Ir para o conteúdo principal
Smartphone release by Sony-- also known as Sony Xperia Z1 Honami, Sony Xperia Z1 C6902/L39h, Sony Xperia Z1 C6903, Sony Xperia Z1 C6906, Sony Xperia Z1 C6943. Released in September 2013.
51 Perguntas Visualizar todos
Why is my xperia z1 had a network problem?
Sometimes, network in my device working as usual. And then, it suddenly change it into "Emergency call only". After that, it has a network back. And then, disappear. It repeatedly every second.
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
Hi,
Try the following.
1. Remove SIM card and reinstall, see how it performs. If still the same,
can you put the SIM card in another phone that is on the same network and see if problem is still there? This will prove whether it is network or phone.
por
Adicionar um comentário
2 respostas
The Sony phone will show "Emergency call only" when the signal is bad. May be you are in the bad reception area. If not, check if the SIM has problem or the SIM card reader is loose.
Esta resposta foi útil?
Pontuação 0
The problem is of SIM Card slot I am also having the same problem.
But don't know how to repair it.
Any ideas?
Pontuação 0
Adicionar a sua resposta
Mohammad Shazwan Shaffie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 3,741
