epson L120 waste ink pad counter full
What should I download to reset my epson L120 memory?
Esta é uma boa pergunta?
Hi,
You can try this site. Download the program, pay $9.99 (click on RESET KEY bottom left of page) for how to pay for key to make program work.
http://www.wic.support/?page_id=134
They also offer a free one time only Trial Key (it only reduces your counter down to 90%) to get you going more quickly
if you look closely at the video in the middle of the page they type the word, trial, in the box for the key
This one program is only one of many, just for your info, you may wish to find one that you prefer by googling reset waste counter Epson L120
Esta resposta foi útil?
it is fake program
Hi Bilal baba,
The program works. It only reduces the counter by 10% (down to 90% full) because it is 'free'. As mentioned in the answer you have to type 'trial' in the box for it to work.
If you want the full 100% fix you have to pay as also mentioned.
Instructions to Reset Epson L120 Printer Memory
If you don't mind take note of that every beforehand buddy epson printer no restriction on the utilization of printing and starting signs can be utilized when the printer would not like to do a test print the message on the PC screen there is composed cautioning shows the ink store is full, this time recently landed a position how to reset epson printer memory Epson L120 most recent discharge in 2014, a review of the most recent printers are shockingly not ready to print on photograph paper media as the printer driver settings are not accessible on photograph paper just be set the default plain paper just. to step reset buddy see the ventures underneath :
https://store.atlanticinkjet.com/epson-i...
Resetter Epson L120 Free Download
Starting step, the printer is on and the usb link is introduced effectively, then my companion first Download Resetter Epson L120 system and when going to run the project first resetter handicap against infection pal's PC.
Step 1 Click Select,
Step 2 to choose the Type Printer buddy,
Step 3 Port select Auto Selection and click OK,
Step 4 Click the menu Particular Adjustment Mode,
Step 5 select Waste Ink Pad Counter menu and afterward click Ok,
Step 6 Check List dimenu Main and Platen Pad Counter, specifically to
Step 7 Click Check later there will be numbers in the Main menu and Platen Pad Counter which implies that the numbers that we need to perform a reset to 0, after officially then amigo ulangin Step 6 then specifically to,
Step 8 click OK and afterward click Initialization buddy berated to turn the printer yet don't unplug the force line on the force and after that turn the printer, completed deh companion and the printer is prepared for reuse.
Find a translator, or post in your native language please and we'll use a translator app. Sorry, but could not understand what you're even trying to say.
Dear Esmeralda:
If you only buy a reset code, and then you do succeed in resetting the counter to zero, in a few months you will find you have ink all over your furniture. The counter is there to tell you to take the printer in to an Epson authorized technician for its required service. It needs fresh waste ink pads installed to hold the wasted ink it sucks through of the print head nozzles when it is cleaning itself. If the pads are full, and the counter is reset, it will overflow and run out of the printer on to your desk. Contact Epson online, look for their service support, and the website will refer you to the nearest service center. They will have Epson software that will do that job properly and give you your printer back as good as new.
Windgod
Il will be enough to clean the waste bin inside the printer (usually it can be removed from the lower part of the printer) There where only a couple of cotton sponges that needs to be cleaned or replaced
I usually do that with using resetter for my L382 printer model. I can suggest your to use the WIC reset utility or browse here and see if there is a reset tool for the L120 model. However, make sure to always have a backup of your machine settings and your content just to stay on the safe side of the road.
For those seeking solutions, you can find a tutorial video on how to reset the Epson L120 waste ink pad counter by watching this video: https://www.youtube.com/watch?v=_FQ7oX5Q...
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 88
Duração total: 79,516
7 comentários
should we bring the printer or what should we do? Thanks and more power....
por chad erille
how to repair my epson l120 ink waste pad
por marybelle09
how to solve printer EPSON L120? Here's the message
(A printer's ink pad is at the end of its service life.)
por APPLE MARCH LASALA
I had used the trial key before and now I need to reset my printer again. Is there any other free resetter key we can use?
por Mafiel Marapao
pls free key re settler for epson L120
por jonald
Exibir mais 2 comentários
