Why isn't my tablet working
My tablet wont come on
Esta é uma boa pergunta?
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
Esta resposta foi útil?
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
The Reason Is Probably Because It Needs To Be Restarted.
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 382
3 comentários
What have you tried? Charged it? New charger;new cable?
por oldturkey03
Can you try to describe your problem in detail? What is the situation of your tablet now?
por William
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
por zionwh123
