Ir para o conteúdo principal
Released November 13, 2011, this is the only model ever released. It can be disassembled with screwdrivers and a small amount of prying. Model # CECH-ZED1U
Why does the sound occasionally sound scratchy and thin?
While using the Sony PlayStation 3D Display, the sound occasionally sounds very thin and scratchy like there is a bad connection. What would be a way to fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
RE:Why does the sound occasionally sound scratchy and thin?
Poor sound quality can be caused by several issues including bad input cables, bad video/audio ports, and bad speakers. You should be able to determine the problem by trying different cables and different input ports. If this still doesn't solve the problem you may need to replace the speakers. Follow the speaker replacement guide to do so.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Logan Simon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 400
