Ir para o conteúdo principal
The Samsung Galaxy Grand is an Android smartphone manufactured by Samsung Electronics and released in January 2013. It is also known as the Samsung Galaxy Z I9082Z in India. Models: GT-I9082, GT-I9082Z, GT-I9082L.
Not turning on after setting android device manager
i activated device manager, activated samsung remote controls then phone turned off, but on turning on, only stays at samsung welcome screen. tried removing battery then turning on again but still the same
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi ,
You might want to try this:
1.On a computer or other mobile phone, visit: google.com/android/devicemanager
2.Sign in using your Google login details that you also used on your locked phone.
3.In the ADM interface, select the device you need to unlock (if it isn’t already selected).
4.Select ‘Lock’
5.In the appearing window, enter a temporary password. You don’t have to enter a recovery message. Now click ‘Lock’ again.
6.If it was successful, you should see a confirmation below the box with the buttons Ring, Lock and Erase.
7.On your phone you should now see a password field in which you should enter the temporary password. This should unlock your phone.
8.Now, before you go on with your life, go to your phone’s lock screen settings and disable the temporary password.
9.That’s it!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
esbguidote será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 323
