Why is the camera on my Le Pan S not functioning correctly?
The image looks distorted when I try to take a picture. I have tried taking several pictures, and get the same results every time.
Esta é uma boa pergunta?
If the image is going in and out, the problem might be a software issue that can be solved by simply resetting the device. If this does not help, make sure that your software is up-to-date. Your camera may also have damage from being dropped on a hard surface or exposed to water. In this case, please see a troubleshooting page for camera replacement at Le Pan S Troubleshooting.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 80
