Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Not powering on with plugged in
Hi, I have a bit of an unusual one.
I have an iPhone 5c that isn't recognising the power cable when it’s powered off. If the phone is on everything works as normal, but if the phone is off, nothing.
I have tried different batteries and charging port to see if they have any affect with no success.
A bit of history, phone has had a screen replacement. No signs of moisture/water.
Original owner said they had always the apple wall plug but had used 3rd party usb cables.
My initial though is maybe a U2 ic but could do with some other input before I go down that path.
Any and all ideas welcome, thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Well, that is a possibility. However, when you hear hoofbeats, think horses, not zebras. I'll admit this sounds unusual. But, before going down the micro soldering path, try teplacing the Lightning dock. Here's parts
iPhone 5c Lightning Connector and Headphone Jack
Here's labor
iPhone 5c Lightning Connector Assembly Replacement
Imagem de iPhone 5c Lightning Connector and Headphone Jack
Produto
$9.99
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks for your insight but I have already tested a new charging port with no success, also the charging port work normally once the phone is on.
por
Right. Have you tried a force restart?
How to Force Restart an iPhone 5
Or backing up the phone, and restoring to a backup?
por
Considering I have replaced the battery I don't think a hard restart will help. I will try a full restore once I get the original to remove the iCloud account from the phone.
por
Adicionar a sua resposta
Duncan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 93
