Ir para o conteúdo principal
What type of screw is on the battery cover?
Hey, I was wondering if anybody could tell me what kind of screw is in the battery cover and where I might be able to find one? My eighty year old grandfather tried to help me remove the cover and stripped the screw...
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
It appears from the guide that it pretty much a standard Phillips head screw.
There are a couple of tri-wing screws on the other end (see step #6 of this guide:
Game Boy Micro Faceplate Replacement
Game Boy Micro Battery Cover Replacement
Imagem de Game Boy Micro Battery Cover
Guia
Nível de dificuldade:
Muito fácil
1 - 2 minutes
Imagem de Game Boy Micro Faceplate
Guia
Muito fácil
5 minutes
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
The screws on the outer shell of the gameboy micro are Tri-Wing Screws, you can try to contact Nintendo Support for the Gameboy Micro and ask if you can order Tri-Wing Screws for the Gameboy Micro from them, if not then you can send in the GBM to repairment to them and see if they'll add the missing screws.
Pontuação 1
Adicionar a sua resposta
surgethewolf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 1,269
