Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Pergunta encerrada
Is that possible to replace basebad chip
Hi,
I got an Iphone 5s in 5$ , it was working perfectly as IPOD, but during updating IOS its stuck in Apple Logo , i show the phone to a local repair shop they said Basband chip is damaged and you need to replace the logic board.
But , my questions is i see many places like Aliexpress, Ebay .e.t.c have Baseband chips available , is that possible to replace the baseband chip only , will device will start and active after replacing ?
Thanks
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Ehh... I dunno. I mean, yes it is possible. I believe. Jessa Jones will know for sure
por
Who is Jessa Jones?
por
Adicionar um comentário
1 resposta
Solução escolhida
Daiyan, the baseband chip is a BGA that will require a reball. So you will need to have a reflow machine as well as the right stencil etc. to do that. Even if you have all that, the IC needs to be pre-programmed to function with your phone, since there are multiple IC that are dependent on each other. Yes it can be replaced, no it is not going to work with your phone.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi, Thanks for giving details , the final option is to replace the Logic board.
Btw any idea or tips to make it out from Apple logo problem , its turning on and Showing ITunes , i used reiboot to make out from Recovery Mode but still its up and turning off after few seconds.
por
Well, again not sure, but you can send it out to a repair shop, that works or specializes in micro soldering
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 145
