What is causing lines through some numbers?
When I turn on my ti84 and type in numbers, some appear with vertical lines through some of them, how do I get rid of the lines?
Esta é uma boa pergunta?
fergam22, that is usually caused by a damaged screen. always make sure that you did a reset and check to make sure that all cables are properly seated. To replace the screen use this guide
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,341
