Ir para o conteúdo principal
Um monitor de áudio digital para bebês com interface DECT 6.0 fabricado em 2014 pela VTech.
Why is my device beeping?
Even when my parent units and baby unit are in range, and there are no large metallic objects in the way, my device will beep. How do I resolve this issue?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
When incoming voice message is recorded, my vtech cordless flashes and beeps endlessly - is there a way to deactivate the beeping?!
por
Adicionar um comentário
3 respostas
Solução escolhida
Check to see how many beeps the unit produces. If the unit has three loud beeps, this means the baby unit is out of range. You must be at least 3 feet in range, any closer and your device will have static. You might also have low batteries, try replacing the batteries by using the battery replacement guide. If this does not resolve your issue, consider the following guides on speaker and motherboard replacement, as that would be the next step in resolving the unwanted beeping problem.
Esta resposta foi útil?
Pontuação 0
2 comentários:
I have the same problem for about a year. The beeping is very annoying. What is wrong with my phone? I have replaced the battery. It didn't help.
por
I have the same problem for about a year. The beeping is very annoying. What is wrong with my phone? I have replaced the battery. It didn't help.i have a vtech cordless phone.
por
My vetch 6.0  cordless  phone has a beeping sound while in use , how do I stop this noise ?
Pontuação 0
So I misplaced my parental unit and have been using my phone for overnights. It’ll play a loud beeping continuously and it sounds like it’s coming from my daughters room, but when I go in there it’s not actually happening, just through my phone. Why?
Pontuação 0
Adicionar a sua resposta
Melany Colon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 62
Ao todo: 30,955
