Ir para o conteúdo principal
Visual Land Prestige Elite 7Q is a 7" Tablet with a quad-core processor, 8GB of memory, and comes with Android 4.4 (KitKat).
screen broke from the inside can I fix it
My tablet got crack from the inside can it be fixed. Some one please help
Esta é uma boa pergunta?
Pontuação 1
2 comentários
does the tablet still work?
Power on can you see the screen and does it respond to touch
por
It turns on but all u can see is liqud. No it does not respond to touch
por
Adicionar um comentário
1 resposta
Pergunta mais útil
patty abarca, from what you are describing it sounds like a broken LCD but intact digitizer. It will help if you post some images of what you see with your question. Use this guide to do so. The LCD's are readily available at places like this and many others. There are no repair guides out, so I would suggest that you check check on here as well as on here for similarities. When you do decide to work on it, [URL|make] create a guide so we can all learn from it.
Imagem de iFixit
Guia
Adicionar imagens a uma pergunta já existente
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de Visual Land Prestige Pro 7D Display
Guia
Visual Land Prestige Pro 7D LCD Display Replacement
Difícil
30 - 40 minutes
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
patty abarca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 437
