Heater control valve cable stuck
I replaced the heater control valve on the Honda Pilot but the cable will not move to side the valve what can I do
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 2,773
can you move the cable while it is not connected? Can you move the valve manually? What year is your Pilot?
por oldturkey03
Check under the dash to see that nothing has got shoved up into the flap to keep it from moving or that the flap has not been pushed into the housing and is stuck in the closed position
por Jimfixer
