Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
iPod has lines on screen
Found this iPod. At first it showed picture then I updated it and it got distorted. Also it was on windows then updated on mac. Buttons still work because I can reset it using menu and center button. Tried restoring, pulling battery, cleaning board with alcohol. Do I need a new screen or logic board?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
rtrigiani, you'll need a new display. Straight forward replacement without surprise. Follow this guide Replacement displays are available right here as well as many other places.
Imagem de Replace a broken or damaged color display for your iPod Video with this part.
Produto
iPod Video Color Display
$29.99
Esta resposta foi útil?
Pontuação 3
7 comentários:
Well the weird thing is this morning I plugged it into my windows laptop and it showed the display. But then i did a reset on the iPod and it went back. Is there anyway to downgrade the software?
por
After not touching it for a day the display turned on. But then it wouldn't react on the click wheel only recognizes reset with center and menu.
por
No downgrade is going to fix that:-). Open it up using any of the guides listed above and ensure that all the ribbon cables are properly seated and the locking mechanism engaged.
por
Double checked yesterday and everything is plugged in. Also did another alcohol cleaning and still nothing. Doesn't look like any rips in the cables either.
por
I'd try a new display and/or clickwheel anyway. If it does not work, it sounds like your logic board is giving you issues.
por
Exibir mais 2 comentários
The lcd/digitizer assembly needs to be replaced. It's impossible to separate the two, if you were gonna try going the cheap route
Pontuação 1
1 comentário:
imedicminneapolis, this is a 5th gen Video. No digitizer, no fused display:-)
por
Adicionar a sua resposta
rtrigiani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 4,601
