water is running back into reservoir
Esta é uma boa pergunta?
hunter, make sure that your needle valve is not occluded. check on here to make sure that the needle as well as the lines are good.
Esta resposta foi útil?
My Keurig Elite When you turn on power button it makes a noise but nothing happens(it says Not ready but does not make coffee then cuts oft) does not pump water.
Remove bottom plate.you will see water pump,sometimes when you hit the pump with a screwdriver handle like a tap it will free the pump
There are 2 solenoid in the machine,one of them is not operating. Apply 12v to test the solenoid ,replace the one not operating
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 4,796
1 comentário
what have you checked? What have you tried?
por oldturkey03
