Ir para o conteúdo principal
Why is my charger not charging my cellphone any more then 9%
I have had it plugged in for 24 hours & it has been either:
• Reducing the battery while charging.
• Keeping it at the same percentage.
• Giving it one percent in like 4 hours
- It has been stuck on 9% for going on 6 hours & I am unable to take it off of the charger or it drains from 9% then dies within 2 minutes of me not using it?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Do you use original charger or apple certified one? does phone getting hot while charging ?
por
Adicionar um comentário
1 resposta
Hi Trinity McQueston ! If you are using the original charger it is definitely a faulty battery from itself. Check by using another charger and if the problem continuous you must change the battery.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Trinity McQueston será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 327
