Ir para o conteúdo principal
Repair and disassembly guides for GE Microwave ovens.
Glue for the plastic touch panel cover
GE Microwave Model# DVM1850DM1WW Ser# ZL900414B - Dec 2006. Plastic touch panel cover keeps coming off - what glue can I use at the edges to keep it on?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I contacted GE and they had no recommendation - see a service person!! Said glue might get hot. (Not satisfactory customer support for me!!) My service cotract says it's cosmetic and can't support - tried, but no glue recommendation - reffered me to GE. Does anyone know of a 'rubber' glue so the panel can be removed for access to the microswitches?
por
Adicionar um comentário
2 respostas
Solução escolhida
I used Scott's double-sided tape. The cover is not flush against the pushbuttons but it works much better than having it fall off several times a day.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I used a thin line of Gorilla Glue. Gently pulled back the panel 1/2 inch or so, cleaned edges with a thin sponge. Left it wet (that's how Gorilla Glue works). Used a q-tip to put the glue on. Taped it real tight with electrical tape long enough for the glue to cure. Removed the tape 24 hours later, works like a charm.
por
Pontuação 0
Adicionar a sua resposta
Jim LeTellier será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 6,844
