Ir para o conteúdo principal
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
Power button pin out?
Hi,
In trying to replace the power button I delaminated one of the solder pads. It's not the ground side, it's the side that just goes to a buried via. Does anyone know where this connects - I'd like to bodge-wire something for now so I can at least get my data off the phone.
There's an image of the problem here : https://www.dropbox.com/s/dxhnafoavvm8k8...
Any ideas?
David
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
David Mills, check to see if this will help. Looks like it goes to R11010
Esta resposta foi útil?
Pontuação 4
3 comentários:
Thanks - just what I needed.
por
Thank you a lot! That was exactly the information I was looking for.
I had the same problem and now fixed it with a little wire bridge soldered between the resistor and the pin of the switch. I don't know how long it will last, but for it works :)
por
Thanks a million! You saved my N5!
por
Adicionar a sua resposta
David Mills será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 2,222
