Ir para o conteúdo principal
Estes fones de ouvido brancos são equipados com um controle remoto e um microfone, e vêm com os tocadores de música e o iPhone da Apple. Eles também são vendidos separadamente. Lançados em 9 de setembro de 2008.
How do I fix a broken volume button?
On the plastic piece on the cord of the right ear bud, there is the control piece that lets you control the volume and the play/pause. The button that turns the volume up is not working, so I need to either figure out a way to fix it, or at least remove the top part of the remote.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
I don't believe that you can fix the problem, likely a piece of dirt got into the volume control and is blocking the contacts however I don't believe the volume controls can be opened without destroying them all together.
It may still be possible to get them replaced by Apple, if the ipod you are using them with is still under warrantee (all new ipods come with a 1 year warrantee which will cover you'r ipod and the in-ear phones you'r using it with, however can be extended to two years by purchasing the applecare program) to check if the ipod is still under warrantee input you'r ipods serial number into this webpage https://selfsolve.apple.com/GetWarranty....
Hope this solves the problem!
Esta resposta foi útil?
Pontuação 1
Just go to android, iPhones are trash ^.^
Pontuação 0
Just get an android, iPhones are literal trash cans ^.^
Pontuação 0
i tried to open mine and then i found this site :( i broke my freaking earbuds
Pontuação 0
Adicionar a sua resposta
John McWaters será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 15,464
